6
This discussion topic has been answered Discussion topic: WiFi constantly dropping out
This message was authored by: K8y51
My WiFi is constantly dropping out and flashing Amber or red on our box. There are no reported issues in the area, but our connection appears to be awful. My wife works from home and this is having a serious impact on her work and output. It's happened three times this morning already and when tested the connection says it's fine even though it clearly isn't
Avatar for K8y51
This message was authored by: K8y51 Answer
Re: WiFi constantly dropping out
Yes I called them and it's an issue outside the house with the connection, so they are getting someone out to check
@K8y51  black or white router from Sky?
This message was authored by: Beth241
Mine keeps doing this too it's been going on and off for about a week. Have you spoken to sky about it yet to see what they say?
@Beth241 Have you run the service checker to see if anything is specifically indicated!
This should determine if there's an identified fault affecting multiple households.
Avatar for K8y51
This message was authored by: lizshirley
My WiFi has been a nightmare since Thursday I keep losing it what do I need to do
@lizshirley Same as you see on post 4 is the place to start!
