Discussion topic: WiFi connectivity
This message was authored by: Antotron
WiFi connectivity
Since we have upgraded to sky fibre, my smart plugs, ring door bell won't connect to the wifi.
i suspect it's because 2.4ghz isn't enabled or working.
Re: WiFi connectivity
@Antotron
All current Sky Hub models broadcast the same SSID on both 2.4Ghz and 5Ghz simultaneously by default.  Some devices struggle with this, and some cannot handle the WPA3 encryption used as a default by the white Max Hub and new Gigafast+ Hub.
Avatar for Antotron
It's a black hub, it wasn't changed when we changed to fttp but that's when everything started not to work.
