Discussion topic: WiFi connection
This message was authored by: Jule-s
WiFi connection
Hello, The WiFi is repeatedly dropping amd has a low signal in the house. I have tested the connection and it says that there are no issues in the area. There is no WiFi connection when you're in the garden.
Re: WiFi connection
That is always likely to happen as a Wifi signal does have limitations.
For your signal issues in your home a poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
