Discussion topic: WiFi connection
This message was authored by: Canningball
WiFi connection
I have just had my sky engineer out to connect my broadband. I am up and running but the WiFi isn't great. I am working from home and the WiFi isn't strong enough the connection keeps dropping off.
Re: WiFi connection
@Canningball
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
This message was authored by: JavelinSam
Re: WiFi connection
I have the same issue, the engineer laughed when i told him of Skys promise of coverage and he was right. i have been given a wifi extender pod but it doesnt work. the only useable locations for it are in a position where the signal is already poor so doesnt add any boost.
