1
This discussion topic has been answered Discussion topic: Issue with internet and Wifi
This message was authored by: StephanieEth
I have been having issues with my internet and Wifi for several days now. My Tv is now not working (cannot get onto netflix etc) and my internet isnt working pn my phone and emails
Re: Issue with internet and Wifi
@StephanieEth
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
@StephanieEth
