Discussion topic: WiFi connection
This message was authored by: SteveStacey
WiFi connection
Hi Having issues connecting to and getting WiFi from the hub. Have an extender that we can connect to but not the main one. Not showing as Having anything connected on the WiFi checker either but there is
Re: WiFi connection
@SteveStacey
If you are saying you have no working broadband then there have been a number of similar posts on here today so they could well be some issues around today.
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
