Discussion topic: WiFi connection
This message was authored by: Elizabethbarr
Message posted on 01 Dec 2025 09:26 AM
WiFi connection
Hi I am
looking to see about talking about my WiFi connection and speed as the signal and speed is very poor
Find out more
Message posted on 01 Dec 2025 10:23 AM
Re: WiFi connection
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
