Discussion topic: Broadband issue
Message posted on 01 Dec 2025 09:44 AM
Broadband issue
Message posted on 01 Dec 2025 10:21 AM
Re: Broadband issue
@Gazzy71_Regan
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Message posted on 01 Dec 2025 10:24 AM
Re: Broadband issue
Assuming you have the Sky max hub, a flashing green light usually indicates it cant fully connect to the internet. I would run a line test to start with and see if that flags anything.
