Discussion topic: WiFi connection
Message posted on 09 Sep 2025 12:25 PM
WiFi connection
Hello,
over the past 3 days my WiFi has been dropping out almost consistently and only working a handful of times.
when I do the diagnostics on sky, it says there are no issues.
please can you help with this!
Message posted on 09 Sep 2025 12:32 PM
Re: WiFi connection
@JessicaEllis
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
