Discussion topic: WiFi connection to hub
Message posted on 19 May 2024 05:10 PM
Hi! Just run the test through the sky website and it says everything is ok. But none of my wireless devices are connecting. My WiFi externder is showing the power and WiFi lights green, but connected is blank. Neither of my sky boxes are connected. Neither of my TVs are connected. Any ideas?!
Message posted on 20 May 2024 10:51 AM
Re: WiFi connection to hub
@Vrtw the result you see intially is from the last routine test you have to click to run the test to see the current position. It can tell you that there is a known fault affecting your area. If it says everything is fine power down your hub for 20 seconds then restart it.
Watch the leds as the hub boots they key one is the internet connection light until that is green your hub has not conected properly if it stays amber there is an issue between the exchange and the hub. If the internet light is green but the voice light if you have one stays amber and nothing connects its a fault at Sky's end. In either case report it to Sky.
