Discussion topic: WiFi connection to box keeps dropping
Message posted on 30 Dec 2025 06:15 PM
Message posted on 30 Dec 2025 06:36 PM
Re: WiFi connection to box keeps dropping
@Emma_C What sky Hub are you connecting to with the sky Q/mini combo currently, if sky Max then you need to do it different way from the norm than if you use a sky Broadband Hub!
Message posted on 30 Dec 2025 07:13 PM
It is a sky max box. Its just frustrating as this has been on going for about a year. I dont have time to call up and spend hours on the phone to them to sort it out for a few weeks.
Message posted on 30 Dec 2025 07:51 PM
@Emma_C Then call sky, have them send a Satellite engineer with a sky Broadband Booster to sort out the wireless mesh between the sky Q box and the sky mini, otherwise find a way to Ethernet connect the sky Q and the sky mini to the sky Max Ethernet port by yourself!
