Discussion topic: Problems
This message was authored by: Digger12
Problems
I have no wifi or broadband for the second time in two weeks
Re: Problems
@Digger12
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
▪️I AM NOT A SKY EMPLOYEE ▪️
