This discussion topic has been answered Discussion topic: WiFi connection in some rooms
Message posted on 25 May 2026 04:19 PM
My WiFi is good but I still can't get a great signal in some rooms. Do I need a extender?
Message posted on 25 May 2026 04:42 PM
You might do as a poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Message posted on 26 May 2026 05:28 PM
Re: WiFi connection in some rooms
Thanks, have contacted Sky and they will send me a pod.
