Discussion topic: No internet connection
Message posted on 26 May 2026 05:38 PM
The check showed that everything looks fine, but there is still no Internet connection
Message posted on 26 May 2026 05:43 PM
Re: No internet connection
@Svitlana5
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
