Discussion topic: WiFi completely turned off. Not discoverable
This message was authored by: Amygunning98
The WiFi had just completely gone down. There's no lights on, nothing. Everything's gone off. The electric is working fine.
This message was authored by: Me134
Re: WiFi completely turned off. Not discoverable
Presumably this is the broadband that is down? Firstly, unplug the hub for 10 minutes and then reboot. Do check the socket itself is working.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app.
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
If the app finds a fault you should be able to report it from there.
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
