Discussion topic: WiFi box orange light
This message was authored by: Karintimmins
The WiFi isn't working I have two orange light one on the insternet the other on voice nothing is loading on my so im having to use my phone data
Re: WiFi box orange light
@Karintimmins
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If you are still having broadband problems later use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
