Discussion topic: WiFi box has orange lights but service checker says it's ok
Message posted on 01 Oct 2025 04:27 AM
Message posted on 01 Oct 2025 05:46 AM
Re: WiFi box has orange lights but service checker says it's ok
@MikeJohno
l’m afraid you aren’t speaking to Sky Customer Services by posting here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If you are still having broadband problems after 7am use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
