Discussion topic: WiFi booster pod
Message posted on 02 Dec 2024 08:49 PM
WiFi booster pod
Just received a booster pod which has connected to the WiFi.
When I click on the pod in the Sky app, it says there are no devices connected. Silly question but does that mean to the Pod?
When I click to connect it gives the option of sharing the existing WiFi log in details
Message posted on 03 Dec 2024 07:55 AM
Re: WiFi booster pod
@LauraNo79 dont try to control which devices will connect to the pod and which connect to the hub the system sorts that automatically. Best advised to plug in the pod when the led goes out it is connected it will take 24 hours for the system to optimise. The pod neds pkacing no more than halfway between the hub and where you nnedd the boost.
