Discussion topic: WiFi blocking DNS traffic
Message posted on 08 Jul 2025 07:32 AM
My WiFi is showing a privacy message and saying blocking DNS traffic.
Message posted on 08 Jul 2025 07:50 AM - last edited: 08 Jul 2025 08:13 AM
Re: WiFi blocking DNS traffic
Specifically encrypted DNS (probably on an Apple device) I'd think.
Without any DNS at all you wouldn't be accessing much.
I believe Sky (like most UK ISPs) doesn't currently support encrypted DNS, probably because this would negate their mandatory web filtering.
Message posted on 08 Jul 2025 08:28 AM
@Mac73 I use Apple's cloud private relay over a Sky connection which works well but reading Apple's forums there are sporadic reports of the message you report popping up occasionally. The suggested fix of telling the device to forget the WiFi connection and then reconnecting seems to sort it. It was assumed the error message is spurious which many error messages are.
