Discussion topic: WiFi being slow
This message was authored by: ZoeBuckton
WiFi being slow
Getting 0.3-1.5mbs most of the day for the past 2 days
any advise ?
Re: WiFi being slow
@ZoeBuckton Run the service checker, expand the broadband with > and see what your 30 day history is like!
Sample below just look at post 4.
Service Checker bars
https://helpforum.sky.com/t5/Broadband/Broadband-speeds-reported-versus-actual/td-p/5171393
Avatar for ZoeBuckton
Re: WiFi being slow
It doesn't seem to show me my 30 day history ? Just the speed as I check it
Re: WiFi being slow
@ZoeBuckton You probably have a serious line fault then, either call sky direct and have them test or try it yourself!
Try running the line test here to see if any faults are found:
