Discussion topic: No internet connection
Message posted on 06 Jan 2026 07:17 PM
I would like support with accessing internet.
Message posted on 06 Jan 2026 07:35 PM
Re: No internet connection
@Bethanie2
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
