Discussion topic: WiFi and broadband not working
Message posted on 12 Oct 2025 02:41 PM
WiFi and broadband not working tried reset switch off and on still not working red lights showing 😑
Message posted on 12 Oct 2025 02:44 PM
Re: WiFi and broadband not working
@Camymcphee
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
