Discussion topic: WiFi and broadband not working
This message was authored by: CaolanElliff
My WiFi and broadband keep dropping out, the light on the hub for the internet turns off, however when I check the connection in the app it says there aren't any issues.
Re: WiFi and broadband not working
@CaolanElliff
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
