Discussion topic: WiFi and Broadband
This message was authored by: H14
WiFi and Broadband
I don't know what's going on with Sky but it's now become BERy frequent and there are constant outages and lost access to Broadband and WiFi, so impacting my hive connection, telephone, etc. and no information shared on why we are experiencing so many outages.
Re: WiFi and Broadband
@H14
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
