Discussion topic: WiFi Max device list, missing item
Message posted on 20 Dec 2024 04:07 PM
Does anyone with WiFi Max have a Main Q box attached, and showing in their list of devices?
Every other device in my house shows up but the Main Q box.
Don't talk to me about mini's. 🤣
Message posted on 04 Jan 2025 12:17 PM
Re: WiFi Max device list, missing item
Looking to re-energize this post if possible!
Message posted on 04 Jan 2025 05:56 PM
yes mine is connected, is your q box WiFi connected or by Ethernet?
Message posted on 04 Jan 2025 06:34 PM
Currently WiFi @mormegil, may I also ask which model yours is, and if the MAC matches those given in the status of the box?
Message posted on 04 Jan 2025 07:16 PM - last edited: 04 Jan 2025 07:16 PM
It's the white max hub
q box has WiFi hotspots turned off as in the same room as the hub so they don't block each other
mac address are different in app compared to settings on the box
Message posted on 04 Jan 2025 07:27 PM
Message posted on 04 Jan 2025 07:31 PM
Message posted on 04 Jan 2025 07:42 PM
Not sure what this is, i'm afraid.
Message posted on 04 Jan 2025 07:47 PM
They blocked the picture
q 2tb hardware version 32b107
Message posted on 04 Jan 2025 07:54 PM
Ah ok, thanks.
Same box as mine then. And you are wifi to that box?
Message posted on 04 Jan 2025 07:56 PM
Yeah I am WiFi to the box
only the Ont is connected with Ethernet everything else is WiFi
Message posted on 04 Jan 2025 08:10 PM
ONT, so you are a Fibre customer? Please tell me, did you WPS this set up, and do you have a mini box?
Thanks 👍
Message posted on 04 Jan 2025 08:15 PM
Yeah I have gigafast
first thing I did in the app was to change the ssid and password to that of my old 4.2 hub so that everything connected automatically
Message posted on 04 Jan 2025 08:23 PM
Smart move, I opted for a new SSID as a form of fresh start.
I've had a lot of trouble, hence a lot of questions.
I even restored the Router this morning.
Do you use a max pod?
Message posted on 04 Jan 2025 08:26 PM
I have never bothered with them as I get 200-600 mbps to my gaming pc upstairs
main thing that blocks my signal is my girlfriend insisting it has to sit under an oak table rather than more centrally in the room
that at the cats constantly knocking it over
