3
This discussion topic has been answered Discussion topic: WiFi Max Router Power Input Voltage
This message was authored by: cruz123
I have installed a new WiFi Max Router using the supplied power supply and cable.  I need a longer cable and note that there is a second input power supply port - a conventional centre pin arrangement.  However there is no indication of the required voltage.  Is it 12V?
This message was authored by: Hussein26 Answer
Re: WiFi Max Router Power Input Voltage
The booklet says 12v. The old sky hub power supply actually fits this port.
Avatar for cruz123
No one can help?
here's a pic of the back of the new sr213, as you see no voltage given over the power in port. IMG_2611.png
This message was authored by: FLC
@cruz123
You can buy USB-C extension cables.
