Discussion topic: WiFi KEEPS DROPPING??????
This message was authored by: Feduplisa
Honestly, for three days my WiFi keeps dropping out. I go through the whole set up rigmarole, get cramp in my fingers and hand pressing this button on my router for so long. Turn everything off at the switch then do the whole thing again and then have to go and then connect the extra box . But apparently no known issues and my phone app says no problem! SORT IT OUT SKY.
Re: WiFi KEEPS DROPPING??????
@Feduplisa you are not talking to Sky by posting in the forum.
Have you spoken to Sky if resetting the system isn't working. You can often diagnose the issue your self using this troubleshooter https://www.sky.com/help/articles/hub-lights-explained-start
