Discussion topic: WiFi Issues
This message was authored by: Asa81
WiFi Issues
We have been experiencing WiFi drop out over the past three days. I have reset the hub a few times but we still experience drop out. Please can we have a site visit to work out what is going wrong. My wife works from home and is an NHS manager.
Re: WiFi Issues
@Asa81
