Discussion topic: WiFi Issues just randomly started
This message was authored by: RyanMac1
My modem seems to be assigning the same IP to multiple devices and half the time when connected there is no internet available.
When running the system check on the sky app says everything is fine. Have tried a factory reset and still not helped.
Currently having to run everything off my phone hotspot in the house.
Re: WiFi Issues just randomly started
@RyanMac1 What sky hub are you using, not heard any DHCP addressing issues with any hubs going on so surprissed by that, do you have any fixed IP's on devices that you have NOT assigned to the sky Lan manager unknown may potentially cause some clashes etc.
Also below about the sky hub as you do not say what is going on apart from your posted info! Was your reset because something cropped up!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
