Discussion topic: WiFi Hub Sudden Red Light
This message was authored by: Moraynewlands
Message posted on 24 Jan 2025 06:29 PM
Red light on Sky hub. Came on about half hour ago knocking out Sky Glass, wifi etc.
Broadband checker says no fault in area (DD3 postcode) . Have disconnected and reconnected cables etc switched off/on etc but still red no wifi.
Anything else I can do?
Message posted on 24 Jan 2025 07:21 PM
Re: WiFi Hub Sudden Red Light
Forget it. Fault found.
A tree has come down out the back and wiped out the streets BT lines 😂☹️
