Discussion topic: WiFi Dropping Out
This message was authored by: AlanEwen
WiFi Dropping Out
My WiFi keeps dropping out when I am using teams, sometimes it is fine but some days it disrupts so much I have to drop out of meetings or I cannot take part or present, it's killing my business
Re: WiFi Dropping Out
@AlanEwen Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
You are using a domestic connection for business which does save money some of those savings are worth investing in s decent wifi system.
