Discussion topic: WiFi Down
Message posted on 06 Feb 2026 08:11 PM
WiFi Down
My broadband hub is displaying two orange lights but when I use the Service Checker, it finds no issues.
Message posted on 06 Feb 2026 08:14 PM
Re: WiFi Down
@Jo396
Message posted on 06 Feb 2026 08:22 PM
Re: WiFi Down
Thank you, I checked my Service Checker now and it says there is a problem, but when I check it, there is nothing wrong according to the service checker.
It also mentions my WiFi is down because of my broadband. After scanning, the broadband is working according to Service Checker but there is no internet when you connect to the router.
