Discussion topic: WiFi Again
Message posted on 18 Nov 2025 02:09 PM
WiFi Again
Wi Fi keeps dropping in and out or is completely unavailable. Is there an issue.
Message posted on 18 Nov 2025 02:38 PM
Re: WiFi Again
@Kelv1
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
