Discussion topic: WiFi 6
This message was authored by: Ee11
WiFi 6
Whilst doing some online courses for work a message keeps popping up to say my WiFi signal is insecure
Re: WiFi 6
@Ee11
Are you using an Apple device if so have a look at this:
https://support.apple.com/en-gb/HT202068
Avatar for Ee11
Re: WiFi 6
No it's not apple device. It's a new laptop
Re: WiFi 6
@Ee11 assuming you have not changed the default settings on the Sky hub your connection is reasonably secure so you can ignore the message.  It could be from the OS like Windows because you have not tokd it that Sky wifi is a home network or from the wifi card moaning thst the wifi security is not using WPA3 the latest standard. The older black Sky hubs only support WPA2 and while the newer white hubs support WPA3  setting them to use that disconnects most of your other devices.
