Discussion topic: Wi fi weak and dropping in kitchen
Message posted on 08 Dec 2025 11:44 PM
Not getting wi fi in kitchen and just upgraded to fibre 150
Message posted on 09 Dec 2025 07:28 AM
Re: Wi fi weak and dropping in kitchen
@Polly36 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
