Discussion topic: Wi fi v ethernet
Message posted on 16 May 2026 09:31 AM
Wi fi v ethernet
i swithed from Virgin to Sky for broadband last year.. With Virgin I had an ethernet connection but with sky it is Wifi. The wifi is stuggling a bit. Will Sky install an ethernet cable to the upstairs and back of the house like Virgin did. If so who to I contact at SKY?
Message posted on 16 May 2026 09:34 AM - last edited: 16 May 2026 09:53 AM
Re: Wi fi v ethernet
@MickBowden No thats not something Sky will do, if you already have an ethernet connection installed by Virgin Media why don't you use that.
Message posted on 16 May 2026 09:48 AM - last edited: 16 May 2026 10:24 AM
If it's actually ethernet then as @GD1 indicates it should be usable as it is.
However I believe Virgin historically installed coaxial cable internally, as they did on their external network.
Coaxial cable can potentially be used for ethernet transit but only by purchasing MoCA (Multimedia over Coax Alliance) adaptors.
Message posted on 16 May 2026 11:21 AM
I'm using these https://amzn.eu/d/0a1x2bsm for my internal network.
Message posted on 16 May 2026 01:57 PM
@MickBowden wrote:i swithed from Virgin to Sky for broadband last year.. With Virgin I had an ethernet connection but with sky it is Wifi. The wifi is stuggling a bit. Will Sky install an ethernet cable to the upstairs and back of the house like Virgin did. If so who to I contact at SKY?
@MickBowden You could possibly look for a local contractor to carry out the ethernet extension. In my case I actually did the work myself by laying This along three rooms , although admittedly i didn't have an upstairs to contend with.
Sky Q 1TB UHD
LG TV
Sky Mobile
