2
This discussion topic has been answered Discussion topic: Wi fi problems
This message was authored by: Wulfric1
Wi fi problems
Everything was fine up to popping out for an hour on return WiFi was down carried out tests and all came back ok both for the broadband and WiFi have  all green lights on hub but still not working  including the sky glass which is connected to hub via cable and not WiFi dependent.
Re: Wi fi problems
@Wulfric1
There are multiple posts from people on here with the same issues as you so there does appear to be an outage.
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
Re: Wi fi problems
@Wulfric1
Avatar for Wulfric1
Re: Wi fi problems
Yes I had checked everything on my sky and it was all coming back saying everything was fine and working and there was no outages, so reset the hub which was on four green lights after reset I had 3 green lights and amber light on voice so went back to old faithful of switching it all of at the wall and waiting 5 minutes then turning all back on it now seems to all be working ok, possible hub update upset it all.
