1
This discussion topic has been answered Discussion topic: Internet not work despite passing sky checks
This message was authored by: AbbyD2
Hi there
im getting an error saying there's no internet.  I've run the sky check and suggests everything is fine but I've been disconnected from my work and recieving the no internet message.  Please can you help?
Re: Internet not work despite passing sky checks
@AbbyD2
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it ~ it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
@AbbyD2
