Discussion topic: Wi-fi issues
Message posted on 04 Aug 2026 10:12 AM
Wi-fi issues
I have recently changed my broadband to your 500 system. The strength of the system is not as good as my old one. In the far bedroom the signal is intermittent, I have a garden office which picked up my broadband no problem, this new system will not pick it up and I only get 4G. When I check for broadband connections I can see 3 other sky accounts in my area with decent signal but mine doesn't show. Why is my old system better than this new one. Can I go back to my old system.
Message posted on 04 Aug 2026 10:19 AM
Re: Wi-fi issues
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
