Discussion topic: Wi fi isn't work
This message was authored by: Wifiiproblem
Wi fi isn't work
I've never had a problem before, but in the last two weeks the wi FI had been working very bad. Today, it isn't work and I need to work. Please, help me
Re: Wi fi isn't work
@Wifiiproblem
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
