Discussion topic: Wi fi down
This message was authored by: WBA2
Wi fi down
No wifi cant stream anything been poor for couple of months now,down to 9mb
Re: Wi fi down
@WBA2
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
