1
This discussion topic has been answered Discussion topic: No internet connection
This message was authored by: SKY5NHSB
I have a connection to broadband router but no connection to internet.  When I do a check it tells me there are no issues but I have not had internet for over 30 minutes
Re: No internet connection
@SKY5NHSB
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
@SKY5NHSB
