Discussion topic: Wi fi connection.
Message posted on 31 May 2026 08:08 PM
Wi fi connection.
Hi.
my WiFi signal keeps" dropping out" and is no longer reaching parts of my flat outside the living room (where the hub is situated).
Message posted on 01 Jun 2026 09:14 AM
Re: Wi fi connection.
@Allistair Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes or buildings with concrete walls. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Message posted on 01 Jun 2026 10:50 AM
I do understand that older buildings can cause an issue, but my electronic gadgets and TV keep loosing signal despite them being in the same room as the hub.
Message posted on 01 Jun 2026 11:56 AM
Hi @Allistair I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
