Discussion topic: Wi fi connection
Message posted on 25 Jun 2025 08:12 PM
Wi fi connection
Centre light on modem is orange and no WiFi...have tried box reboot and also disconnection of power reboot still got orange light in centre ????
Message posted on 25 Jun 2025 08:30 PM
Re: Wi fi connection
This explains the lights on the hubs:
Try running the line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 25 Jun 2025 08:32 PM
@hooch1R If you have the three light hub from sky the orange middle light, the internet is down, could be home, local, area wide, just about anything, try the service checker to see if you can get any information from that. Link is below.
Message posted on 25 Jun 2025 10:09 PM
Problem sorted out of date old router gave up the ghost .new one on its way...
Message posted on 25 Jun 2025 10:15 PM
@hooch1R If indeed you had/have the old skyQ hub, then was due to be replaced so do expect to get the newer Sky Broadband Hub in its place as the replacement. See the link below about the hubs.
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
