Discussion topic: Wi-fi Stability Issues
This message was authored by: BradenS1995
We recently (Tues 27th) got sky broadband installed. We're using a Hub Max (white) through a fibre line. We get the broadband speeds advertised to the router although the Wifi stabiliy is abysmal. Constant connection drops even when I isolate 2.4GHz / 5GHz. I had no stability issues with virgin media's router they provided. I can't find a contact number to request an engineer to come look but this router's performance is appalling. It's probably no wonder I am provided constant adverts for "wifi boosting" equipment from Sky.
Re: Wi-fi Stability Issues
@BradenS1995
Try running this line test to see if it finds any faults:
This message was authored by: Dawn9436
I have same issue as Branden that posted I just upgraded from my old sky broadband to the new fibre 300 and i have to say my broadband  and wifi is shockingly worse off  - i run the online test and it says all is good but its just simply not as good as before!! My fire sticks are constantly  freezing, I work from home and pages take significantly longer to load than they did beofre on my old sky broadband and my wi fi to my top floor is shcoking  - when i was able  to finally speak to someone at sky regarding my boradband he told me that its standard practice to reset my router once a month  - never heard somethign so rediculous  in all my years and i told him so  - never had to do it with my old sky router EVER!!  My call was then disconnected so I didnt have the enegry to call back again!!
