Discussion topic: Wi-Fi trouble
This message was authored by: MNaff
Wi-Fi trouble
I have problem to connect to internet at home
it is dropping and currently not working
Re: Wi-Fi trouble
@MNaff
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
Re: Wi-Fi trouble
@MNaff Would advise you stick to the one post and not jump on multiples, answered on your other and linked!
