Discussion topic: Wi-Fi settings
Message posted on ‎21 Dec 2023 09:50 PM
Wi-Fi settings
Quite some time ago I set a user name and password for accessing my sky wifi settings. However, I've now lost those details and wondered if there was anyway of resetting them with a new user name and password.
Message posted on ‎21 Dec 2023 10:44 PM
Re: Wi-Fi settings
@menot+you You can reset the routerr with a factory reset and this will then let you login with the information on the back of the router. The only downside to this is any custom settings will have to be re-input.
Message posted on ‎22 Dec 2023 07:48 AM
Re: Wi-Fi settings
@menot+you to perform a factory reset press in the reset pin until the power led flashes which can take up to 20 seconds as if you release before thst the hub just reboots.
