Discussion topic: Wi-Fi range
This message was authored by: Eds
Wi-Fi range
I have a Sky Max router ( white ), still not providing Wi-Fi to extremes. I received a range extender from Sky which has two Ethernet ports, can I connect it to the router via one of the ports
Re: Wi-Fi range
Yes, but unless that's a long ethernet cable to move the pod into another room it won't make any difference.  The signal from a  'range extender' is itself no more powerful than that broadcast by a router because WiFi power output is regulated by national legislation.  Ideally an 'extender' needs to be halfway between wireless source and client device.
