Discussion topic: Wi-Fi not working
This message was authored by: John1051963
Wi-Fi not working
To talk to someone
Re: Wi-Fi not working
@John1051963 wrote:
To talk to someone
@John1051963
This is a customer ▶️ customer discussion forum where we try to help other customers. You haven’t actually contacted Sky by posting on here.
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
