Discussion topic: Broadband dropping out
This message was authored by: GulliverT2903
For the past few weeks my broadband keeps dropping out, sometimes for seconds and others for hours like now!! How do i speak to someone at sky as i am going round in circles trying to contact them.
Re: Broadband dropping out
@GulliverT2903
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
